The PCI-6115 has large (up to 32M available for DAC analog out) FIFO memory. Can I load a waveform into that memory and have the board continuously loop and generate that waveform without requiring further transfers from computer memory ?
If so, could I re-load part of that waveform to modify it while that generation was going on, or would the generation have to be first stopped ?
While continuously generating on one channel, could the other channel's static DC output level be changed ?
