01-14-2010 11:05 PM
I am using PCI 6052E, SCXI chassis 1001 and SCXI 1530 for my DAQ system. I am using Labview 8.6 and Traditional DAQ.
I tried to set different scan rates. The maximum scan rate I can reach is around 100,000. Once beyond 100, 000, there is an error message “the clock rate exceeds the board's recommended maximum rate”. I checked the maximum scan rate can be 333KS/s and the maximum internal clock can reach 20MHz. Why does this happen, Any idea? I am only using one channel from scxi 1530.
Solved! Go to Solution.
01-17-2010 03:23 PM
Have you seen this KnowledgeBase article? You system will be limited by whichever component has the lowest maximum sampling rate, in this case that should be the 1530.
-Christina
01-19-2010 02:17 PM
Thanks for reminding me this.
The maximum scan rate of scxi 1530 is 125Ks/second...I got 100, 000 from experiment, any idea about the difference?
