I'm using C#, NI-DAQmx 8.5, and the GenDigPulse_DigStart example. I have an oscope hooked up and I can see the 5v 100hz square wave being sent to pin3 - so far, so good.
The problem is that the task never triggers. If I change the example to use StartTrigger.ConfigureNone(), it triggers and I get the expected output signal.
I'm having a hard time troubleshooting this. As I mentioned, I see the signal going into the cable to the card. Is there a way I can read the raw signal from pfi9 to see if the signal is getting to the card?
Thanks!
John Duddy
