In a VB 6.0 application, I do an AI read of 7 channels every .5 sec, the scan rate is 2000 Hz,
and the number of scan is 1000. To avoid buffer fill up too quickly, before every read
I reset the card, reconfig, and then read using AcquireData, then stop.
So far, as the application runs for about half an hour I'll get this run time error:
"Error 10444 - No more system memory is available on the heap, or no more menory is available on the device
or insufficient diskspace is available."
I rule out diskspace and system memory. However, I don't know what else to do. Please advice.
