Thanks I found the example for CVI and is sure works. One moe thing, If the
function times out the system becoms sluggish. Is there a way to increase
this timeout value?
LVilla
"Filipe A." wrote in message
news:50650000000500000049900000-1027480788000@exchange.ni.com...
> Ivilla;
> That device you have doesn't support such operation.
> What you can do to workaround that fact is to configure the DAQ task
> to do Conditional Retrieval. That is sort of an analog trigger, the
> difference is that the NI-DAQ driver compares the input values to the
> specified trigger level, as opose to the hardware, as it is on boards
> that supports analog trigger.
> That would make the acquisition a little slower, since every point
> needs
to be checked by the driver. If you need faster acquisition than
> that, you will need to purchase a board with analog trigger
> capabilities.
> Hope this helps.
> Filipe A.
> Applications Engineer
> National Instruments
