01-26-2012 05:38 AM
I have downloaded and unzipped the NI_6010_Help.chm file from NI. When I open it the window's right message pane says "Navigation to the web page was cancelled", and none of the left-pane contents can be viewed. An old NI FAQ posting claimed this was a Windows security setting issue, but the solution suggested (changing a file Properties attribute) there did not apply to my Win Vista system.
Solved! Go to Solution.
01-26-2012 01:36 PM
Hi src42,
This is a problem with the enhanced Windows security. If you copy the .chm file to your desktop, you can right-click and open properties. At the bottom of the General tab is a button that says "Unblock". Click on this, and then click OK. You will then be able to open the file without any issues.
We are sorry for the inconvenience.
-Jeff
01-26-2012 01:41 PM
I tried this earlier, and no "unblock" option is available in my Vista setup. I do seemingly have Full file permissions granted, though.
01-26-2012 01:51 PM
Hmmm. Let me look into it. Unblock is what you do on Win7, and I assumed it was the same on Vista.
01-26-2012 05:03 PM
Unfortunately, one of the Windows security patches made opening .chms a little more difficult for Vista and XP users.
I've attached a PDF of a newer version of the 6010 manual to this post. The "preliminary" stamp is just an indicator that this manual isn't actually released yet.
---Robin
