Hi Filipe,
Its happening with all our applications. So I guess its not related to particular program or application. They were working fine in previous CVI versions. Our application acquires data using PCI-MIO-16E-1 device of NI. We r plotting the acquired data and also do analysis. However, the PC hangs for any run time error right from memory allocation errors to errors in printf. I have to restart the machine once it gets hung. The other obeservation is when program was small, it didn't give this problem. But as I continued adding more stuff in it, its size(executable size as well) increased and then it started giving this problem. Same happens with all the other applications. Thats why i said its related to memory or stack that CVI 6 is using.
Let me
know if u need anything else.
cheers
niranjan
