11-10-2020 11:17 AM
I am currently stuck. I need to have a DAQ interface through LabVIEW and output a constant Voltage. not a signal. Basically, I need it to activate a relay once I activate it in LabVIEW. is this even possible? I have both a Digital IO DAQ and an Analog IO DAQ.
11-10-2020 02:41 PM
What specific devices? On many common DAQ devices, analog outputs will hold their last voltage level after you stop (and even clear) the task. I don't think digital outputs do the same, at least some common ones I've worked with definitely don't (M-series, X-series).
But you'd also need to determine from your specs whether the AO channel can source enough current to drive the relay coil.
-Kevin P
