I currently use a USB-9215 and a USB-6501 in a test system used onboard helicopters. The upper temperature limits for these two devices are spec'd at 60 deg C and 55 deg C, respectively. I want to add an analog output capability to the system, so I was looking at combining all three functions by using a USB-621x device. However, the upper temperature limit is spec'd at 45 deg C - significantly less than the two devices.
What is the symptom if a USB-621x device is used above 45 deg C? Will it damage the device, or will it just be out-of-spec? Is there a particular function in the device that is affected: analog in, analog out, DIO?
If anyone can provide some knowledgable help I'd really appreciate it!
