10-12-2004 04:30 AM
10-21-2004 08:54 AM
11-08-2004 11:06 AM
10-18-2006 09:22 AM
Can the above link be corrected as I need this same information and can not access the link.
I am told I do not have permission to access the link.
I need help as all my users could not access the ni_dmm_32.dll unless we gave them power user permissions under XP.
Scot Hudson
850-251-4784
10-19-2006
10:56 AM
- last edited on
03-31-2026
10:39 AM
by
Content Cleaner
Scot,
Thanks for posting the NI Forums. I am not sure what the link was intended to be above; however I was able to track down some information that might help. Take a look at the following KnowledgeBase article:
How Do I Give Non-Administrators Full Control Over National Instrument's Products:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIS6CAO&l=en-US
Let me know if this does not fix the problem and I will see if there is something else you might be able to try. Good luck with your application. Keep me posted on how it goes.
Neil S.
Applications Engineer
Message Edited by Neil S. on 10-19-2006 10:56 AM
