10-15-2013 02:40 PM
I got a pressure transducer from omega with three wires: red (power supply+);black (power supply-); and white for single. It has output voltages from 0 to 5.
The transducer needs a supply voltage between 9 to 30. So I used a NI 9263 to supply the power (9V) with red and black wires.
I used a Ni 9205 to read the single voltage.
I read the insturction of Ni 9205 and I know there are three different modes: DIFF, NRSE, and RSE.
But in these modes, it seems like I need another wire. Is that true?
I really don't understand. I only have one single wire. How could I do these connections? Can someone give an example in the case of RSE mode?
Thanks!
Solved! Go to Solution.
10-15-2013 10:51 PM
Wire the black wire to both 9263 and 9205 (no matter you use DIFF,RSE,NRSE). Be careful that 9263 may not drive enough current for the sensor.
10-16-2013 11:12 AM
Kateb,
Thanks. Which channel should wire the black wire in 9205? Common?
10-17-2013 08:41 AM
Please.....
10-17-2013 12:08 PM
Wire the black wire to COM, port 17.
