03-26-2009 05:31 AM
In our latest shipments we have received the new version NIDAQ-MX v8.7.1. But the card, which is a 6071E, does not seem to be supported by this sw. On earlier versions like 8.6 the driver was installed automatically, but not in the new one. When trying to install a driver manually the card does not show in the list.
Solved! Go to Solution.
03-26-2009 06:14 AM
03-26-2009 08:39 AM
The latest version is actually 8.9 and in the readme, the 6071E is listed. Try installing this.
03-26-2009 09:31 AM
03-27-2009 08:39 AM - edited 03-27-2009 08:40 AM
03-29-2009 11:45 PM
Could you please do a favor? Please mark Dennis post as solution to your problem and not your post. Hope you understand.
Mathan
03-30-2009 02:05 AM
Sorry about that. I understand. But how do I change the tag? I can't find where to remove / add the solution label.. Anyone?
Atle
(Novice)
03-30-2009 06:38 AM
Atele wrote:But how do I change the tag? I can't find where to remove / add the solution label.. Anyone?
In your post which you marked as solution, just click on the Options menu located at the top right corner of that post and select "Unmark" . Then click on the options menu at the top right corner of Dennis' post and select "Mark as solution".
Mathan
03-30-2009 07:20 AM
