Multifunction DAQ
Noisy signal reading using PCI-6036E
Hi.  I'm using a PCI-6036E multifunction DAQ card and an SCC-2345 with a SC-AI03 (+/- 10V input).  My question is, what sort of accuracy should I expect from such a setup?  Right now I have a signal that is essentially 0-10V and it seems to be accurate to about 2 decimal places.
I realize that noise can creep in from a variety of sources, however I don't believe I'm getting noise from anything external (ie other electronics or equipment).  I don't think I'm in an electronically noisy environment.  I've measured the voltage with a relatively cheap fluke multimeter and that seems to be good to at least 3 decimal places.  I can filter the data which I have and sure it is somewhat cleaner, however I would have expected better results than I'm getting without resorting to filtering.  As it stands I'd like to be able have at least one more reliable decimal place of accuracy.
I also made sure to hookup a resistor (10K) from pin 3 of the SC-AI03 to the AI sense line, but that didn't seem to make any difference.  I also tried a few other resistor values, just to see if there was any difference, but no luck.
Anyone have any experience with the above sort of equipement?
Chuck
(2,938 Views)
Hi Chuck,
When you say that you're measurements are only accurate to two decimal points: is the third decimal point constantly fluctuating or are you only getting two decimal points back as your data?
Also, here are a couple of knowledgebases, including one with a link to an online accuracy calculator, that you might find helpful:
How Do I Calculate Absolute Accuracy or System Accuracy?
Field Wiring and Noise Considerations for Analog Signals
Hal L.
(2,921 Views)
