Not new in this subject, But I am as well very curious why I get so much noise (a perfect 50Hz noise from probably the lights in my office) when I connect an external 5V DC power supply to my SCB-68 connection box to my laptop using a 6062-E DAQ card.
Using RSE on ACH1(+5V) and AIGND (0V) I have no noise, a perfect straight line.
Using Diff on ACH1(+5V) and ACH9 (0V), and using 68kOhm bias resistors between ACH1 and AIGND and ACH9 and AIGND, I have noise in my signal (from a 50Hz source).
Also strange: if I disconnect my laptop from its external power supply, so running on batteries, the noise is reduced, but still apparent.
A simple solution would be to use always RSE, for all my sensors. However, this is contrarely to what NI recommends, and I have some cases in which I want to measure a DIFF signal, for example, I want to connect a K-type thermocouple. When I connect this to ACH1 and ACH9 (reserving ACH0 for the onboard CJC sensor), I get large fluctuations (seems like white noise).
How to overcome this problem? I cannot select RSE for my thermocouple using DAQMAX. Is point-by-point averaging the only solution?
Any ideas on this -apparently existing- topic are highly appreciated!
Thijs
