Multifunction DAQ
Noise on a single channel of a Task with multiple tasks
I am using a NI PCI 6221.
I am trying to measure four analog voltages by clubbing them into one task using DAQ assistant.
One of the channel is trying to measure the amplitude of some voltage pulses. I can see the pulses, but with noise. Amplitude of noise is about 20% the amplitude of the actual voltage pulses that I want to see.
Can I filter noise in that particular channel?
(3,494 Views)
Rather than that, I would suggest you to first determine what is causing that noise and try rectifying on hardware level.
It may be due to inproper signal connection/ grounding etc.
If you scan this channel alone, do you still observe this noise??
I am asking this to determine if there is any cross talk occuring between neighbouring channels
(3,489 Views)
Thanks for the reply.
It is actually voltage picked up by a coil.
With a continusous AC waveform that is appearing (which I am not interested in), I am have occasional pulses/spikes. I am more interested in the pulses than the continuous AC wave form. Is there way that I just see the pulses and filter the AC waveform on that single channel?
Anyways,
I do not have any grounding issues.
There is no cross-talk.
(3,480 Views)
Of course you can index/assess that particular channel from the scan list and filter it as per your requirement
You have quite a bit of filtering options in LabVIEW.( you have digital FIR and IIR filters)
The best to start with, would be an express filter vi
(3,470 Views)
You could also implement a high pass filter with resistors and capacitors to allow spikes to pass but block the AC signal.
What frequency is the AC waveform?
(3,458 Views)
