I'm trying to use the PCI-6259 for an Analog Input application & the documentation on that is non-existent.
Specifically, for the AI_Configure(,,,,,) and AI_Read(,,,) the parameters are unclear.
1. Device Number - What exactly is this? (the explanation in the help file says "assigned by Measurement & Automation Explorer") but there is no parameter called "Device Number" in MAX. I assume this is 1 if the MAX calls the device "Dev1" and 2 if its called "Dev2" etc.
2. Chan - "Channel Number to be configured" - The page "DAQ Device Analog Input Channel Settings" does not list PCI-6259 at all.
3. Input Mode, Range & Polarity - Settings are supposedly explained in the page "AI_Configure Table" but again, there is no mention of PCI-6259 at all.
I've used NI-DAQ drivers before and has worked well but guidelines to program this device is just non-existent & I don't see how anyone can figure it out by looking at the documentation available. I tried to program this device on the same lines as I had before but the driver returns an error -10401 (not an NI device or not recognized) when I execute the AI_Configure. Does anyone know anything about this device at NI?
NI-DAQ version on the system is 7.3 and the card works well on MAX Test panel, however.
