I discovery how to solve this problem doing:
First go to linux Yast.
Applications--System--Yast (or from the console type /sbin/yast2)
You will be required to login as super user (root).
Then on the left hand side you will see on the top software
and in the right pane you should see a list of options. Depending on
your version of linux (9,10,10.1 or greater) you need to click on the
one that allows you to 'search'.
In my version: 10.1 i click on: "Software Management"
Then search for kernal, or for 'source'.
You will see on the right side checkboxes.
Check the one that says 'kernal source'.
Click next-->finish (inserting the appropriate cd's, or just that dvd).
But after, i get anoter error msg while installing NIKAL14.iso:
******************************** ERROR ****************************************
* Kernel source in /usr/src/linux does not appear to be
* configured for the 2.6.13-15-smp kernel.
* Configuration of kernel source is required to continue installation. *
* Refer to the README file for the product you are installing for information *
about configuring your kernel
source.
Now i have a different error.
Message Edited by alexandrearc on 05-17-2007 02:20 PM
