@jdwright wrote:
Does anyone use MacOS 9 with NI-DAQ 6.6.1? I want to determine if is a stable configuration.
I decided to avoid Mac OS X for this particular project because OS X does not support NI-DAQ. However, I didn't realize that uprgrading from NI-DAQ 6.0.0 to 6.6.1 would be so problematic.
I don't use Labview so I can't tell you about that. I wrote a plug-in that allows our main product to interface to NI DAQ boards; it runs on Mac OS 9. One complication is that there are two drivers in the NI-DAQ 6 installers: NI-DAQ 6.x to support E-series boards and NI-DAQ 4.9 to support pre-E-series boards (PCI-1200, etc.). If you are using one of the non-E-series boards you will need to select 4.9 from the custom install options.
My plug-in is written in C, which was a problem because they didn't ever release NI-DAQ Software library for 6 on Macintosh. I was ultimately able to talk them out of an unsupported library that supports only E-series boards under NI-DAQ 6 on OS 9.
As I say, I don't know how all this applies to using Labview to access the DAQ boards.
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
