02-11-2021 08:42 AM
I have a NI 9264 in a NI 9189 Chassis. The card shows up in NI Max. I can create a task. When in Labview the NI 9264 does not show up as selection for physical channel when trying to write analog voltage. All other cards, NI 9205, NI 9211 show up as selection for physical channel. I am using LV 2017.
02-18-2021 10:19 PM
It might be related to the channel filtering of the control/constant: I Can't Find My DAQ Device in LabVIEW DAQmx Physical Channel Control
02-22-2021 09:44 AM
It was...not sure why LV doesn't default to no filter then allow you to filter as needed.
Anyway thanks for the reply.
