Multifunction DAQ
Ni-6154 AO high hop greater than original signal.
Support Question:
I am making an application using PCI-6154, which comprises of frequency range 1
Khz-0.1hz and the sinusoidal perturbation as low as 26 mV peak. I am limited to
start my work because of PCI analog out sine perturbation because it have some
hop at freq range 1 Khz- 1hz which itself is greater than the original signal
peak, i am attaching some files for your reference please have a look at it.
why does this appears?
any way to get rid of this behavior?
Warm regards
(2,233 Views)
(2,205 Views)
