10-11-2006 02:14 AM - edited 10-11-2006 02:14 AM
Message Edited by perk_bud on 10-11-2006 02:16 AM
10-12-2006 11:47 AM
Hi perk_bud,
Rather than using a separate DLL, I’d suggest just using Visual Basic to perform the DAQmx function calls. There are a lot of examples located in the DAQmx folder.
C:\Program Files\National Instruments\NI-DAQ\Examples
This folder contains Visual Basic examples, as well as C examples in case you do decide to use a DLL.
Also, the DAQmx help documentation contains some good information. Check out the “NI-DAQmx C API Visual Basic 6.0 Help”. This is located in the Start menu under Programs >> National Instruments >> NI-DAQ.
Hope this helps!
Ed Waxler | Applications Engineering | National Instruments
10-13-2006 01:42 AM
