Multifunction DAQ
Need to use NI PXI-4204 card for +28V analog input generation.
Hi Guys,
I'm using NI PXI-4204 card for generating +28V analog input but I'm not able to access this card in NI MAX and getting following error.
There was a problem resetting the device.
Status Code: -209852
The specified device is no longer supported within the NI-DAQmx API.
Please suggest me any workaround, so that I can use this existing NI PXI-4204 card for Analog input.
I'm using NI DAQ-MX 2023 Q1 & NI DAQ-MX 2023 Q4 Runtime Driver in my system.
(182 Views)
According to DAQmx readme, PXI-4204 is last supported in NI-DAQmx 19.0
PXI-4204 is no longer listed in NI-DAQmx 19.1 readme.
If you are using LabVIEW, the last version you can use is 2019.
Control Lead | Intelline Inc
(153 Views)
