03-17-2009 10:51 AM - edited 03-17-2009 10:53 AM
Solved! Go to Solution.
03-17-2009 11:25 AM
Are you also looking to sample the DAQ at 1 Hz?
My approach would be to use the DAQ acquisition to time your loop displaying the reading each acquisition and then use the loop counter to control the logic of your file write. For 1 Hz and a 10 minute write i would use "quotient and remainder" i / 600; if remainder= 0, then write data point.
For date and time, under Timing pallete use the Get Date/Time in seconds feeding a Format Date/Time to string.
03-18-2009 07:06 AM
