Chris,
I am attaching an example that does exactly that for sine waves. You can replace the sine pattern VI with
the Pulse pattern VI included with the Full Development system:
From the functions pallette
Analyze >> Signal Processing>>Signal Generation
Hope this helps.
Thanks for contacting National Instruments
Example Program Document
Title: Continuous Analog sine Output on multiple (two) channels with different frequencies
Description: This example is a modification of a continuous analog output example that ships with LabVIEW so that output can be done simultaneously on both analog output channels of an e-series type board
. Specifically, this program generates sine waves of different, user-specified frequencies on each channel.
Software
Group: LabVIEW
Version:
Language: G
Version: 5.0
Required Add on Kit: Full Development System (FDS)
Hardware
Group: DAQ
Driver Info: NI-DAQ
Version: N/A
Required Hardware: E-series board with analog output
