Multifunction DAQ
Need help with DAQmxGetDevAIGains
Could someone please give me an example of how to use DAQmxGetDevAIGains?  Like many functions in the DAQmx C API, I can find only the barest of documentation.  The documentation shows:
    int32 __CFUNC DAQmxGetDevAIGains(const char device[], float64 *data, uInt32 arraySizeInSamples);
        Purpose
        DAQmxGetDevAIGains gets the I/O Type >> Analog Input >> Gains property
I tried using it like so:
    double gains[32];
    int err = DAQmxGetDevAIGains("PXI2Slot2", gains, 32);
where the device at PXI2Slot2 is a PXI-6250.  The call returns with err == 0, but the gains array is filled with garbage (-7.8e+298).  I've already created a task and at least one AI channel before I try to get the gains.  What am I doing wrong?
Larry
(3,748 Views)
Hi Larry,
I am familiar with a similar property that I can use withoput problem in LabVIEW. Let me if I can find an example in C that will help us figure out what you are doing wrong. I will post back monday afternoon with an update.
What environment are you programming in? If you would like to, you could also post your code and I can take a look at it.
Mallori
Mallori M
Sr Group Manager, Education Services
ni.com/training
(3,728 Views)
AI Gain is pretty much only used on SCXI devices so when you query it for for available gains on a regular DAQ card it just returns an empty array. What you're probably looking for is DAQmxGetDevAIVoltageRngs().
Cheers,
Andrew S
(3,715 Views)
Hi Larry,
He makes a good point. I believe I have only used the Gains property node with Dynamic Signal Acquisition (DSA) cards and SCXI in the past. Some links that you might find helpful with regards to DAQmxGetDevAIVoltageRngs() are:
Format of DAQmxGetDevAIVoltageRngs
how to list AI input ranges by daqmx
I hope this helps,
Mallori
Mallori M
ni.com/training
(3,707 Views)
