Multifunction DAQ
Need Info On PXI 6071E card
I need to generate analog voltage from 0V to 2.5V with resolution step of
2mV. Can i achieve this by using PXI 6071E card..?. Since i have this card
with me already, i want to know whether i can make use of this. Can you
please help me out..?
Regards
Dayanand
(2,184 Views)
According to the manual, the two analog outputs are 12 bits (4096 steps) and can be programmed for -10 to +10, 0 to 10, -AOEXTRef to + AOEXTRef and 0 to + AOEXTRef.
If you program the 0 to 10V range, 10V/4096 steps = 2.44mV per step. So that's pretty close to your 2mV resolution.
I do not know about using AOEXTRef, it may give you finer resolution if you can apply a voltage less than 10V and still resolve it into 4096 steps (i.e. 5V/4096steps = 1.22mV resolution/step) Maybe someone else can cmine in on the use of the external reference. And then there is always the manualwink smiley
(2,179 Views)
