03-08-2014 12:14 AM
Hi everybody.
need help. actually i am working on DAQmx for current. i want to know how can i use DAQmx if i am at home. i cannot have device all time with me. tell me about virtual DAQmx by making setting on my DAQ program that its virtually attached. i want to see my output without hardware
Regrads
Qasim
03-10-2014 02:30 AM
HI,
one of my friend help me regarding DAQ about virtual..i have design DAQ virtual using NI max software but now this error occured
i have done that ad still getting 2 errors. i have attached files. i m using virtual DAQ
03-10-2014 06:11 AM
According to the error, you are trying to set the minimum value to something outside of a desired range of +-40mV. What device are you using? Can you share some of your code?
03-10-2014 10:07 PM
Hi
i have attached a doc. actually i want to run 2 DAQ devices together. as virtual DAQ i cannot fix on current. with voltage it run with one DAQ and i get simulated signal on DAQ 1 only other donot give any simulated signal. kindly help me. i have make DAQ using Ni max and run in this program in block of physical channel.
i try to send u my file .vi but it cannot be attachedso i m sending u pic of my work
