05-22-2017 07:52 PM
I ran into problem with app on mac and nidaqmx base drivers. It is related to forum reports and NI CAR# 611729 I think.
This problem seems to be reported by many users since more than 2 years with a different CAR # (#528664)
Is this been resolved in 17.x of the nidaqmx base drivers? No mention in the readme files. Please fix the problem!!
06-01-2017 01:41 PM
This issue is currently being investigated by the support/R&D teams. It is something that our engineers are aware of, although it has not yet been fixed.
11-21-2017 07:03 AM
I am also running into problems running my NI-cards on the Mac (NIDAQmx Base 15). The code is written in C and compiled with XCode (7.3) under ElCapitan (10.11). The compilation is executed without errors and I can execute the created 'mex'-file properly until the first reference to the NI-code.
The code runs perfect under MountainLion (10.8) called from a 32-bit application. As you can tell by the versions of OSX used, I have been postponing the transition to 64-bit for several years. I cannot, however, wait any further, because I need some critical other functionality that is tied to 64-bit applications.
Do you have any idea about when one can expect a solution?
MacPsi
11-22-2017 11:31 AM
The problem reported in CAR #528664 was marked as fixed and tested with OSX 10.11.4, Xcode Version 6.1.1 using LabVIEW 2016. Have you had the chance to test it in LabVIEW 2016 / DAQmx 16.X version?
As for the newer CAR #611729, I unfortunately cannot speak to a specific timeline for a fix, as this is still under review with R&D.
Paige C.
