NIDAQ with screw terminals or OEM with HE10 connector ?
Hello
I want to use a USB-6351 board in a fixture test.
This NIDAQ device exists in a box or version OEM. But with the box version, the end connectors are screw terminals.
But how is it possible to disconnect everything to send the device calibration? Does it exist a "16 pin mal connector" to not lose the pinout?
(1,698 Views)
National Instruments doesn't support hardware modifications and will not usually assist in doing so. The OEM version seems to match what you need to achieve. I suggest you get back to someone from the sales team at NI to discuss solutions regarding your project.
Best regards.
(1,676 Views)
