NIDAQ PCI6110 cannot reach its maximal analog output samping rate in C++
Hi!
I got a problem when I try to use C++ to control the NIDAQ instrument: PCI6110 for analog output. Everything works perfectly until I set the sampling rate to 4Ms. I checked the specs for PCI6110: the maximal sampling rate (the maximal update rate) is 4Ms. But when I set it to 4Ms, the error code:  -200332 appears (please see below photo). And it returned that the maximum sampling rate is 2.5Ms instead of 4Ms.
Code:  DAQmxErrChk(DAQmxCfgSampClkTiming(taskHandleAO, "", 4000000, DAQmx_Val_Rising, DAQmx_Val_FiniteSamps, 1)); // 1 means 1 samper to generate for each channel.
I also checked the device using Matlab with the code: devices = daq.getDevices
It shows that the device has rates from 0.1 to 4Ms for analog output:
So my question is: why there is a 2.5Ms limit when I use the C++ program with NIDAQmx.lib? How could I get to the 4Ms sampling rate?
Thank you so much for your time and help!!
Ning
(216 Views)
Accepted by topic author NingZ
The spec sheet shows this pretty clearly.  Max of 4 MHz for 1 channel, max of 2.5 MHz for 2 channels.  So the *device* capability extends to as much as 4 MHz (but only with a 1 channel task), while your 2-channel task's capability only extends to 2.5 MHz.
-Kevin P
(205 Views)
Thank you very much! I should have looked through the spec thoroughly..
(192 Views)
