Multifunction DAQ
NI9233 pulse counting
Dear all
I will use our ni9233 to measure sound from 2 microphones.
I would like to develop some circuit or buying some sensor that I can connect in the ni9233 to counting pulses from a tooth wheel.
Attached are an image from the equipment that i use in other equipment B&K., I stepdown the output voltage for 1 Volt DC from the sensor output and enter in B&K 3rd microphone port.as pulses between 0V and 1V
I saw this post but I could not understand
https://forums.ni.com/t5/Multifunction-DAQ/Eddy-Current-Probe-measurement-with-NI9234-how/m-p/439787...
Best regards
cpalka
(639 Views)
Hi Friends
Can the crankshaft sensor be used to connect the output signal in serie with ni9233?
https://www.youtube.com/watch?v=P2e2DBOqhOU&ab_channel=iTechTube
Best
cpalka
(597 Views)
