Multifunction DAQ
NI9219 - Possible to read one sample per read? (ADCTimingMode set to High Frequency)
I'm trying to take samples every 0.1 seconds from an NI9219.
I set up then converted a DAQ Assistant to code, because I had to change the AI.ADCTimingMode to High Speed. Sample rate is set to 10 Hz, and the samples to read are set to 1. This is all in a while loop. However, each iteration through the loop is returning 10 samples every one second, not 1 sample every 0.1 second.
The VIs are attached if it will help, LV2011 format.
Thanks in advance to any who take a stab at enlightening me as to why this is!
(3,495 Views)
Accepted by topic author Xooch
Ack, had the "number of sample" input of the DAQmx Read VI wired up inadvertantly. Disregard! Smiley Sad
(3,488 Views)
