Multifunction DAQ
NI6289
Hi everyone:
I want to use 2 USB 6289 to collect 30 chanel differential AI signal.
but due to one USB 6289 only has 16 AI channel. so that I must use 2 USB 6289 to acheive this application.
how do I know these 2 USB 6289 device delay time??
do you have this kind of experience before
br
vincent
(1,936 Views)
What do you mean by "device delay time?"
In general, I'd try to approach sync between different devices by sharing a sample clock.  Let device A be the master that exports its sample clock out to a PFI pin.  Device B will be the slave that imports its sample clock from a PFI pin.
You'll need to physically wire this sample clock signal between the two devices' respective PFI pins.  It'll probably be a good idea to run a physical wire beween their DGND pins too.
Then in your programming be sure to start the master task *last*.   That ought to do it.
-Kevin P
CAUTION! New LabVIEW adopters -- it's too late for me, but you *can* save yourself. The new subscription policy for LabVIEW puts NI's hand in your wallet for the rest of your working life. Are you sure you're *that* dedicated to LabVIEW? (Summary of my reasons in this post, part of a voluminous thread of mostly complaints starting here).
(1,910 Views)
Hi Kevin_P:
thanks for your response.
In my case, we have 2 USB 6289 then you suggest to use wire to connect device A PFI 0 and device B PFI 0.
Is it correct??
br
vincent
(1,849 Views)
Accepted by topic author vincent2615
Yes.  Then you'll also need to do the appropriate configuration in the tasks to export the signal from the "master" device/task to its PFI0 pin and then configure the "slave" device/task to get its sample clock signal from its own PFI0 pin.
Here's an idea of what some of that config might look like:
- Kevin P
(1,839 Views)
thx Kevin
(1,835 Views)
