hello all,
I am a mech eng student who has never touched Labview before until a
few weeks ago. so forgive me if my problem is blalantly obvious.
I am trying to make my usb 6008 produce a square wave through so i can
feed it to a simple dc motor and measure the response with the usb6008
through its analog ports. I understand i must use some sort of buffer
to copy and reproduce the wave again and again. i could not find any
examples of waveform generation for this device. it is all very
confusing. Please help!
errors I get using DAQ assistant:
Error -200077 occurred at Property Node DAQmx Timing (arg 1) in Waveform Buffer Generation.vi->squarewave gen.vi
Possible reason(s):
Requested value is not a supported value for this property.
Property: SampTimingType
You Have Requested: Sample Clock
You Can Select: On Demand
Task Name: _unnamedTask
