08-13-2020 04:58 PM
Hello, I am a newbie on this forum. I want to connect the photoelectric sensor BX15M-TDT (through-beam) with the NI instrument (USB). Kindly recommend the suitable NI USB and how to wire (connection) with that NI USB.
08-24-2020 08:26 AM - edited 08-24-2020 08:28 AM
You need a 12V 40mA power supply and one digital input and may one additional resistor (5k to 10k) . Timing critical ?
USB 600x or any other USB box with at least one digital input is fine.
Usually with an additional powersupply for the sensor.
(You can even abuse a COM port (or USB2RS232) flow control line if available , but that could be considerd as a hack 😉 )
Depending on what you have or buy, the manual will help you or you ask again with the type of device...
