08-06-2009 03:14 PM
Hello All,
I've posted a reply to this issue in a separate forum.
Please look here for more info.
-Justin
10-23-2009 11:47 AM - edited 10-23-2009 11:49 AM
07-08-2010 09:37 AM
I had been getting the same type error with a USB cDAQ 9172 utilizing a 9481 relay module. The error was very intermittent. I had found that the power supply voltage to the cDAQ 9172 chassis was dropping down to extremely low levels at times. I corrected the issue and this appears to have solved the problem.
09-23-2010 07:56 AM
just read your post. I also encountered problems with a NISE-100 computer. Same type: fanless and low power consumption.
Problems like windows instability occurs together with USB DAQ-Devices like USB-6008 or USB-6210.
Did you solve yours in the past one and a half years?
Regards Markus
09-28-2010 03:59 PM
No. I solved it by getting a Netbook running Windows 7. Only a slightly higher power consumption and a much better computer.
