09-20-2014 07:46 AM
I have NI USB-9161 carrier and NI 9215 and I can't connect them using max. So I have looked and It seems that I need to use old DAQ base drivers.
I downloaded that old drivers and Used DAQ Base list devices, it finds my card. Then I want to create task but I cant select my device..
Any suggestions?
Thanks in advice
09-24-2014 02:00 AM
Dear pawhan11,
Could you give us more info about the OS you are using? Could you also give us more info about the DAQ Mx Base Version? Maybe there is a case of incompatibility between your OS and DAQ Mx Base interface.
Also, aren't you able to address your device by name? (manually enter Dev1/ai1 , for example)?
Izabela
