Multifunction DAQ
NI USB-6211 no AO generation
Dear all,
I'm currently stuck with my NI USB-6211. I'm trying to generate a voltage waveform via an AO channel. I also want to record some signal (AI) and generate some pulse train using a counter.
I'm coding a C++/Qt software using the DAQmx ansi C library.
The Code I'm using worked, I used it extensivly on a different project (different computer). And It worked at the beginning when I installed it on the current. Then after trying to generate a pulse train it stop working  (without any error send by the card) so I tested the card in NI max and even there nothing was working (both AO and CTR).
I noticed that when I try to start a task I observe a spike on the oscilloscope but that's all.
I tried to plug/unplug the card but without success.
Thanks in advance for yout help
(68 Views)
Accepted by topic author oBlanc
Well, the card started to work again... no clue about what happened.
(31 Views)
