Multifunction DAQ
NI-USB 6009 Not Recognized by NI-MAX
I have two NI-USB 6009 cards.
In the NI-MAX application, when I connect card 1, it is correctly detected and assigned the name Dev1, and I can use it in LABVIEW.
However, when I connect card 2, NI-MAX does not recognize it, labeling it as USB\VID_3923&PID717B, and displays the message "Windows does not have a driver associated with your device," which prevents me from using the card in LABVIEW.
How can I solve this problem? I have already tried different versions of NI-MAX without resolution. Both cards were working fine weeks ago. I currently use LABVIEW Community and NI-MAX 2023 Q4 (running on Windows 11).
(1,604 Views)
Try these steps.
NI USB DAQ Device Not Identified Correctly In NI MAX
NI MAX Not Recognizing USB DAQ Device When Connected Through USB 3.0
https://tmesystems.net/
(1,561 Views)
Accepted by topic author JRAMX
I followed the steps as described here https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kIVESA2&l=es-MX. However, I was unable to resolve the problem initially.
In the Windows 11 Device Manager, the card was listed as USB-6009 with a "?" symbol. So, I right-clicked on the card and selected the "Update Driver" option. A window appeared where I chose the "Search automatically for drivers" option, and Windows 11 updated the driver, and the card was recognized. This created a category in the Device Manager list labeled "NI Data Acquisition Devices," and within it, the USB-6009 card now appears without any configuration issue symbols. After this, NI-MAX correctly recognizes the card, and it can be used in LABVIEW.
Now the card works fine.
Thanks for the help.
(1,556 Views)
Hi. I have the same exact problem, except when I search of automatic drivers, it won't find any.
Any ideas? This is driving me crazy
(853 Views)
