Multifunction DAQ
NI SweptSine.vi produces Error -200077 when in differential mode vs RSE?
I am using the labview Sound + Vibration Toolkit's SweptSineFRF(DAQmx)_SoundAndVibe.vi and trying to measure response from two devices using the differential mode on the DAQ Configuration tab.  Everything works fine when using the RSE terminal configuration but when I switch to differential the program gives me an Error -200077 and says the initalization program fails.  Any reasons to why this happens?
Josh
(3,284 Views)
Hi Josh,
What is the hardware you use?
This sounds like hardware doesn't support such a terminal configuration.
Please also define whether it causes from AO or AI?
Regards, Kate
(3,277 Views)
Sorry, I solved my problem.  I didn't realize that the program cannot output as a differential signal.  When I changed this feature to RSE everything worked as usual.  Thank you for your reply.
(3,274 Views)
