01-29-2018 12:27 PM
Hello
I have an NI PCIe-6361 Card. The Single Board Computer with which i want to use it does not have any PCI/PCIe slot in it . Is there any possibility to use PCIe-6361 Card with some commercially available PCIe to USB adapter?
Thanks & Regards
01-30-2018 06:17 PM
Hi ASIM_BHATTI,
I have looked at National Instruments' products and I did not find any PCIe to USB adapter. That being said, 3rd party adapters may work with our hardware but are not guaranteed to interface correctly. Are you able to find any adapter's online?
Michael B.
Applications Engineer
01-31-2018 07:10 AM
Hi Michael B
Thanks for help. No, until now i am unable to find any suitable adapter/converter module. Do you have some in mind?
Thanks & Regards
01-31-2018 03:14 PM
Hi, ASIM_BHATTI
I unfortunately don't have any in mind. From my quick online search I was unable to find any.
Michael B.
01-31-2018 06:23 PM
You may want to consider the USB-6361.
PCIe is a low-latency memory-mapped bus. USB has much higher latency and is packet-based. I would not expect a generic "PCIe-to-USB converter", if one existed, to perform well. (The USB-6361, on the other hand, is designed with USB's bus considerations in mind.)
02-03-2018 01:08 AM
Thanks. We are already using USB-6361 but wanted to utilize existing PCIe-6361 in stand alone mode.
Is there any other (other than USB) solution possible to use PCIe-6361 in stand alone mode?
Thanks & Regards
