07-28-2021 02:53 PM
08-03-2021 10:37 PM
This is not something I've ever tried and I can only poke around the API with a simulated X-series device.
MAX suggests that there *is* an allowable indirect routing available to push the 100 MHz timebase out to any of several PFI pins. Note: "indirect" routing generally consumes one of the counters.
The DAQmx Export Signal *Property Node* allows a few more options than the similarly named vi. None of them seem to allow an explicit specification of the 100 MHz timebase though. The best candidate I see is under Clocks->Sample Clock Timebase. To test this out, I'd make some kind of dummy task that I explicitly configured to use the 100 MHz clock as a sample clock timebase. Then I'd use the Export Signal Propety Node to try to route that sample clock timebase out to a PFI pin.
No guarantees b/c I can't check with real hardware, just describing what I'd *try*.
-Kevin P
