Multifunction DAQ
NI PCI-6503 driver will not install
I have downloaded the driver for this device from your website.
The installation fails with a message
specified file not found:[MsiEngine] WinNTpath = supportFiles\instmsiw.exe
correct the ini file and try again
This error occurs when I try to install
NI-DAQmx Ver 8.
and exactly the same error occurs when I try to install
NI-DAQ (legacy) Ver 7.4.1
either of which, I understand, will drive my hardware.
The file instmsiw.exe exists in the folder which contains all the unzipped data from the zip file.
I am using Win XP but it is installed on my D drive because I am in a multi-boot configuration.
(1,995 Views)
Hi Cardy,
You may find the following links helpful.
This explains what the instmsiw.exe is:
http://ae.natinst.com/operations/ae/public.nsf/web/searchinternal/5af5aec49f316ee186256fb3006a2004?O...
These links contain proceedures that that I would suggest trying:
http://forums.ni.com/ni/board/message?board.id=250&message.id=6715&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=146572&requireLogin=False
Hope this helps you,
Emma R
NIUK & Ireland
(1,945 Views)
