Hello-
I can already guess the response of my question will be "Sorry, unfortunately not all funcationality is implement for the 6031E in OSX under the Base drivers...."
I upgraded my data acquistion from OS9 and LV6 to OSX and LV7 and so far it has been nothing but a nightmare. Turns out about 25k of hardware I have sitting around isnt compatible and might never be again. I've worked around so many problems already it is getting ridiculous and the only reason I havent reverted back to LV6 is ... ? stupidity I guess. After I switched to the new version, I rewrote my software in mx base and everything seemed OK although it is much slower in both loading and effective data collection rates. I am now scaling everything up and need the rest of the channels on my cards (64 SE). It turns out that I am unable to acquire data in either SE or DI mode for any channel above 15. I tried a second 6031e card to the same result. Is this a known problem? can anyone verify if these channels work on other installations? Is it finally time for me to revert back to LV6 to get full functionality ?
Brad
