NI PCI-5122 and PXI-6143 XP Mode compatablity
Are NI PCI-5122 and PXI-6143 supported in XP mode in Windows 7?
(2,922 Views)
Accepted by ebraunfl
Currently, no NI-DAQmx hardware is supported in Windows XP Mode on Windows Seven.  This is because the way that Windows XP Mode is implemented does not play well with high performance hardware.  PCI/PXI devices will definitely not work and USB devices are very unlikely to work.  Ethernet based devices may work, depending on the device.  NI-DAQmx is not officially supported on any virtualized OS.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(2,921 Views)
