Multifunction DAQ
NI MAX error [error -10856 at AI control
my system:
daqcard1200
os  xp-pro
nidaq 6.9.3
max 2.2
ive resently started to have trouble with my AI channels.
it started with them giving bad readings ,getting lots of transient spikes on the AI cannel data
and now when I do a test in NI-MAX it returns a message of
[ ERROR -10856 at AI control ]
everything else works on the card.; AO, databuses triggers timers and clocks.
ive read that the 1200 cards have been ESD sensitive,
is my problem a simple system incompatibility issue
or have i managed to fry my card ??
(2,210 Views)
Hello Brandmatat!
Have you changed something in the configuration(OS, card, application) or did it occur without any intervention from your side?
Best Regards
Ashwani S.
National Instruments Sweden
(2,191 Views)
was using the card on a laptop when the problem started. the system setup was reading a ratpuls by preassure bladder, via biomed..
it was working perfectly for 4 months then suddenly the card went bad all in and out channels were spiking and giving really odd data, tried to figure it out but to no avail. now I'm trying to see if i can get it working again but now im using it on a desktop same problem with the AI but now everything else seems ok.
(2,183 Views)
Have you tried repairing the daqmx driver and MAX?
Ashwani S.
(2,175 Views)
