07-06-2018 09:24 AM
Using a NI 9209 to measure voltage which represents pressure.
Voltage should be between 0 and 5.
Pressure is between 0 and 200.
I created a Custom Scale in NI-MAX where slope m = 200/3.52 and b = -176/3.52
I created a Task in NI-MAX to use the custom scale.
When viewing the Task, what should I have as values in the Signal Input Range's Min and Max boxes? I have Min = 0 and Max = 200.
07-10-2018 02:05 AM
Have you already read this thread?
07-10-2018 04:10 AM
The Max and Min are to match your pressure. In other words, the Max and Min should be values AFTER the scale has been applied.
