‎02-25-2013 12:13 PM
Hello, I am using LabView for the first time and have gotten familiar with the tutorials regarding for loops and various math functions, i have also gotten Vi's written to operate my HP 6624A quad output power supply and My Agilent 34401A DMM. I have installed Measurement and automation Explorer Version 4.0.0.3010
As i run the "Measurement and automation Explorer" i can see the NI-DAQ devices that i have installed and when i select a device "NI PXI-6640E" Multifunction I/O
it is recognized and will perform Self-Test function with Passing results. I can also utilize the [Test Panels] and properly set Port 0 Bit 0 as an Output. I can also switch it High and Low from the Test Panel control switches and see the results functioning properly using a volt meter across Pin 52 (P0.0) and Pin 50 (D GND) using the NI CB-68LP break-out board.
My problem is with LabView 6.0, ....there seems to be an absolute absence of Tool Palets for I/O controls for NI DAQ Vi's like "DAQ Assist"
i cannot find any VI's or tools of any sort that will allow me the capability to control the outputs or inputs to my Installed I/O devices from LabView 6.0
I have also exhaustively looked through all the tutorials and Help files to no avail...
Can anyone please help
P.S. I understand that LavView6 is an old vintage, but it is what it is, my boss says that i am stuck with it until the next budget infusion...
‎02-25-2013 01:57 PM
The DAQmx driver was introduced with LabVIEW 7.0 and there is no support at all for version 6.0. I cannot find a PXI-6640 so whatever device you have, it must be supported by the obsolete traditional DAQ driver if you need to use 6.0.
‎02-25-2013 03:17 PM
I made an unfortunate typo, where it read "NI PXI-6640E", it should have been "NI PXI-6040E" ...
I am attempting the downgrade to Traditional DAQ (Legacy) 7.4.4
https://lumen.ni.com/nicif/us/infodaqtradwndws/content.xhtml
I hope that "Traditional DAQ (Legacy) 7.4.4" is downward compatible to LabView 6.0,... will keep you posted...
‎02-25-2013 03:50 PM
I had near success, after installing "Traditional DAQ (Legacy) 7.4.4" the Digitial I/O tools now appear in my LabView 6.0 Tools Pallet
but wehn i pick a "Write Digital I/O" vi. it pops an error: "LabView Load Error Code 9 : VI Version (7.0) is newer than LabView Version" (6.0)...
Not sure where i can go from here....
‎02-25-2013 04:03 PM - edited ‎02-25-2013 04:03 PM
Sorry. I knew that 7.4.4. was the last version of traditional DAQ. I did not know the earliest version of LabVIEW that it would support. You might want to browse through the Support link at the top of the page. I quickly checked a couple and 7.1 shows support.
‎03-12-2014 01:22 PM - edited ‎03-12-2014 01:27 PM
I have gotten Labview 6 and DAQ working by installing version 6.9.3 first, making a copy of the DAQ folder and daq_ctls.llb found in the vi.lib folder, installing traditional version 7.4.4, then recopying the DAQ folder and daq_ctls.llb.
I do not have the same board, but it works for a PCI-6013 and a DAQ PCI multi-channel voltage source (cannot remember the model number).
This method has worked on every PC I have ever installed on, even works for Windows 7.
