I am attempting to read a single AI channel from a PCI-6024E card via an SCB-68. I have created a NI-DAQmx Analog Input Voltage Task in MAX for this channel, sampling in contiuous aquisition mode at 100 kHz, 10000 samples at a time, with RSE terminal config. If I use the Test feature from MAX, the channel acquires data as expected.
In LabVIEW, I call this task using an DAQmx Task Name Constant. If I right-click this constant and select "Edit Task", the Daq Assistant opens and I can use the Test feature from the DAQ Assistant to see that the data is still being acquired as expected.
However, when I try to programmatically read this channel in LabVIEW using the VI "DAQmx Read (Analog Wfm 1Chan NSamp).vi", the VI returns a constant DC value of 500 mV, which I know is incorrect (I can monitor the signal across the two terminals in the SCB-68 with a DMM to know that the signal coming in varies as expected, and as I read using the test panels). This erroneous reading occurs even if I make a new VI, drop the task name constant on the diagram, right-click the task name constant and select "Generate Code - Example" and let LabVIEW create its own acquisition loop (which is very similar to what I already set up, using the "DAQmx Read" VI).
Any ideas why the Test Panels work correctly but the LabVIEW code does not?
