06-12-2015 10:10 PM
My installation o f NI-DAQmx fails with the following message
Fatal Error!! Required NIPathsDir property NIMDFBINDIR is undefined.
I have tried 9.8.0 and 14.5, both have the same issue.
Running 32 bit Windows 7
Ideas?
06-13-2015 05:44 AM
It seems I get different ones for other versions. For NI-DAQmx 9.2.2 I get
MAXAFWDIR is undefined.
06-15-2015 10:09 AM
Hi Roland,
This error may occur if you move or delete "My documents" or "My Picture" folders. National Instruments installers require the existence of a 'My Documents' and/or a 'My Pictures' folders. Check that these two folders are there.
06-22-2015 09:13 PM
It worked!
Thank you so much. For those who have the same issue, restoring the user folders in windows 7 is described here
